Saving TWI settings for materials and Sun
Walt
Post by Walt » Wed Dec 17, 2014 11:36 pm
I should know this and can't remember and can't find an answer in manual. I want to quit SU with the materials and light settings just the way I left it when i quit session but have to start over. :oops:
OS: Win10
SketchUp: 2016
Re: Saving TWI settings for materials and Sun
Post by Chris » Thu Dec 18, 2014 2:54 am
With V2 you can create environment presets that are saved between sessions and can be applied to any model.
As far as materials, what do you need to save that isn't saved into your scene?
Walt
Post by Walt » Thu Dec 18, 2014 3:59 am
For instance if I set a wood material to be semi gloss or a pool of water with a bump to make it look like riples or a procedual how is all that saved so when I come back to the model my changes are saved in TWI. I used to save XML in Kerkythea but with TWi as a plugin for SU not sure how to do that.
Walt
Post by Walt » Thu Dec 18, 2014 4:24 am
Wow that was a Dah moment wasn't saving SU when I quit session because all my changes where being done inTWI not SU. :oops:
Post by Fletch » Thu Dec 18, 2014 5:01 pm
I am confused. You were not saving your SU file? or?
Definitely save any changes you make to your SU file even if you are working with Twilight inside the file. Any change you make with Twilight is saved with the SU file.
