bad allocation
- SketchUp: Sketchup 2020
bad allocation
Hello there, i am so sclose to finish another one work, but ther eis one problem i have never seen yet. i start render and it starts rendering very well, i left the computer turned on and when i came back, i swa the window of error ''bad allocation'' after some times it crashes. what is problem can you explain me? how solve this problem?
Re: bad allocation
This is most likely due to running out of RAM memory. If the problem continues, may need new or more RAM.
Re: bad allocation
Yes, but i have many models and ther are more bigger in size then this one and twilight works perfect with them
i have 16 gb RAM, its not small i create this last one during 1 month hope i will find any way to render it.
Re: bad allocation
if you get this error, next time please look at the RAM usage at the time. If you have a lot of high resolution textures the RAM can be taken up.
It may be that there is a bad sector in the RAM.
Re: bad allocation
is it a RAM s foult? i see it first time. there where problems when Twilight can not render, it was saying that that render failed, but never happened same. it stops rendering near to 4-5 % ( 5-1000) i think there is an other problem
Re: bad allocation
error
Re: bad allocation
naah, i try to upload error image but forum dont let me, i mean there is not button PLACE IN LINE
Re: bad allocation
You upload images all of the time, Giorgi, nothing on the forum has changed.
Try running diagnostic on the file.
Extensions>TwilightRenderV2>Diagnostic Report
Users browsing this forum: No registered users and 69 guests
