Bye-Bye Blue Sky
Locked
Bye-Bye Blue Sky
Post by Fletch » Sat Apr 03, 2010 12:46 pm
"What is this blueish color result on my rendering?"
well, it's from the blue sky 'shining' onto your model... but it could stand improvement.
It is recommended to get rid of this quickly and easily in post-pro by using the white point feature in your image editor... takes only a few seconds
Choose pull-down menu in Photoshop, for instance, Image>Adjustments>Levels then choose the "white" eyedropper and click a point on a surface in the scene that is supposed to be white.
But another tip for users of Photoshop (or perhaps Gimp?), that works very nice and perhaps other editors have this features as well, is to use a photo filter to eliminate it in about 5 seconds.
This author set up an automatic action in Photoshop so that it can be done instantaneously at the press of the play button.
Create a photo filter layer over the top of your image as shown below.
  1. Use Warming Filter
  2. Set the color to RGB 100,100,80
  3. Set the layer opacity between 35 and 50 depending on how strong of a blue removal you desire.
  4. Couple this with using the recommended sky template here, and your blues will be gone in no time. :D
Re: Bye-Bye Blue Sky
Post by Fletch » Wed May 05, 2010 7:58 am
Using Picasa (fantastic free image editor from Google) to achieve same effect in 3 clicks:
Use Picasa to view the image, then follow the steps shown:
  1. Effects Tab
  2. Warmify
  3. Glow (adjust top slider as desired)
Then, of course, do a "Save-As" of the image.
Also nice is:
  1. Effects Tab
  2. Warmify
  3. One-click-color fix button
  4. Glow (adjust top slider as desired)
JGA
OS: win7 pro 64 bit
SketchUp: 2015 pro
Post by JGA » Tue May 11, 2010 1:23 pm
Thanks for these tips, they help make a more professional image.
I never thought of Picasa, but it works well for a free package.
My "proper" image editor is Corel Photo-Paint. I'll need to figure out how to adjust the colour balance properly, as it tends to be a bit hit 'n miss at the moment.
JGA
Locked
