Diamonds, Wine Glass, and Spoon by Massimo
Posted: Mon Nov 22, 2010 11:00 am
Massimo shared this scene as part of a
tutorial at Kerkythea forum.
You can
download the model ready to render in Twilight in our Freebies section.
This image has no post production (no photoshop).
Re: Diamonds, Wine Glass, and Spoon by Massimo
Posted: Tue Nov 23, 2010 1:53 pm
by massimo
Here is my try...
Posted: Tue Nov 23, 2010 1:54 pm
by massimo
...Well I've only tried to repeat that render made with Kerkythea all "inside" Twilight, using materials and presets that come with the program. No post work af any kind.
For the render was used the "Easy 10 interior +" preset, 138 passes.
Materials:
- for the spoon was used the "silver" mat from the N-K metals library;
- for the diamond the "diamond" materials from the "gem" library;
- for the glass the "common glass" from the "realistic glass template";
- for the platform again the "common glass" a bit tweakened. The bottom face was painted with a very dark flat colour in order to avoid double reflections on the glass's top. (see the picture below).
Lighting
Only a HDR called
"Ennis Brown" (see the picture below for settings).
Below you can also see some images of the set-up and settings.
Posted: Tue Nov 23, 2010 5:35 pm
my hat is off to you! It looks as close to the original as I could hope for.
Posted: Wed Nov 24, 2010 10:11 am
by Sepo
That is one great setup and render.
Posted: Wed Nov 24, 2010 10:18 am
by massimo
Thanks Fletch and Sepo.
