Rietveld's sideboard
Re: Rietveld's sideboard
Looks better
Have you thought of maybe trying Thom Thom's plugin for creating geometry from a greyscale image for the floor/wall? It's a little bit like having displacement for SketchUp.
Yeah, I've tried that one, but I assume it works only with very low resolution maps because I wasn't able to do anything...
Have to give it another try.
Exactly, read the thread I link to above very carfully. I think it will be useful, after getting used to the technique.
The same floor and the same wall...( ) but a different mood. This time were used only the sun & sky portal as lighting (gamma 0.85, exposure 1.7). The first image is raw Twilight output while the second has a bit of post work.
- Raw Twilight output
- finale_sun.jpg (416.91 KiB) Viewed 11382 times
- With post work
- finale_sun_c.jpg (517.29 KiB) Viewed 11541 times
like your style. unusual in the Italian design. it must be acknowledged, Italy is famous for its furniture designers
This is not italian design http://en.wikipedia.org/wiki/Gerrit_Rietveld
I like the mood a lot!
Cheers.
Jerome
Cheers.
Jerome
I'm sorry , I thought Massimo from Italy, I confused it
Thanks to both.
@ Alvydas I'm not a designer (I'm an architect, a teacher, a town planner and a former photographer of architecture) and I do these renders mostly for fun using objects that I like.
@ Indeed Jerome as I wrote in the subject.
for the casual render hobbyist I would say it's a great image... but for you, my respected friend, I would say that the wood seems lifeless on the sideboard furniture. It may be fun to experiment with the saturation in the high-key image of just the apples, to draw the eye across the image more strongly. And it would be nice to see it higher res, but the floor is still a tiny bit
Your crits are totally spot on! Thanks Fletch.
