Bottles, glass and caps
Modeled in SU.
Easy 10 - 120 passes and no post pro of any kind.
- ultima_finale_2.jpg (649.57 KiB) Viewed 14388 times
- Cattura.JPG (231.23 KiB) Viewed 14370 times
Re: Bottles, glass and caps
Sono sorpreso
Gorgeous. Meniscus and all.
- SketchUp: SU8 to SU2019 Pro
oh WOW....!!!
Salute....
...and I'll have a glass of that red please...!!
Salute....
QUESTION: How thick is the glass bottle
Thanks everybody for the kind words.
@Alvydas your italian is very good... The bottles have slight different thickness for different parts (the bottom, the upper part of the neck for example), but the "normal thickness is around 1,5 mm, maybe a bit thin;
@Fletch, cheers;
@Gareth your italian is good too and also I do prefer red wine.
@Fletch, cheers;
I tried to do red wine once and failed dismally yours looks perfect! <sigh>
In an effort to find a single problem, I got the magnifying glass out!
The only criticism I could come up with is the two bottles on the right, at the very top are a little square and so look plastic rather than glass!
You are a legend!
Those corks are great!
You are a legend!
Well pdwyer the dark red wine is just the "wine red" from translucent mat pack (in reality that mat is made with a dark ruby gem ior/nk file). The other two was made in KT but you can easily replicate it in Twilight: some tweaked sss mat (rubber ball for example) or, if you want a more transparent look, some gems mat.
Can't see exactly the square you're talking about as all the conjunctions are rounded. If you are referring to the cylindrical ring on top of the neck, I've checked all my wine bottles (many... ) and they look nearly like those.The only criticism I could come up with is the two bottles on the right, at the very top are a little square and so look plastic rather than glass!
A bit of post pro...
- ultima_finale_2_post_pro.jpg (693.14 KiB) Viewed 14902 times
Massimo...
I've said it before and I can only repeat myself...
You're a Master with TWR...
It's such a joy to see your work...
Users browsing this forum: Bing [Bot] and 84 guests
