"Organic" aircraft (Eric Lay's RatBird)
I need to work on my "organic" modeling skills, so I went through the tutorial by Eric Lay in the most recent version of SketchUcation CatchUp. It was a good exercise and I learned some good tricks. Below is my result, rendered with a "toon" shader (to be available in Twilight Render 2.0 ).
- toon.png (180.71 KiB) Viewed 13881 times
Re: "Organic" aircraft (Eric Lay's RatBird)
If this is not a secret, what new things awaits us in TW2 ?
Yes, what can we expect ?.
Probably speed increase ? (cfr. Kerkythea)
erikB
erikB
- SketchUp: 2014
Nice model Chris and I like the Toon shader.
Looking forward to TW2.
- SketchUp: 8 Pro
Yeah! Good job Chris and great job Eric!
Like hearing that there is an update around the corner!
What was the render time for this? (Just thinking about animation)
Off hand I don't remember. I'd have to re-run it. It was pretty fast, I believe, because it doesn't have any bump or specular which are two of the biggest factors for slow renders.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 58 guests
