Antique/Dusty Mirrors
Re: Antique/Dusty Mirrors
Hmmm. I am not familiar with the kt material editor.
Thank you anyway
I've downloaded Sergio's Antique Mirror texture and applied it to the mirror top of a coffee table.
How would I set up the material in Twilight so that the surface reflects and also has the texture visible, as in Sergio's image attachment at the start of this thread? I see where Sergio mentions that he used a procedural.....?Re: Antique/Dusty Mirrors
You will be best to have Pro version and build your own dusty mirror material. For those who don't have pro, I will share a scene for you. Here is a scene you can copy the table top texture and use it in your model. It utilizes the texture in order to define the dust, replace existing with any texture you like.
If you try to render the attached scene, be sure to load the provided .hdr file into your spherical sky slot.
With Pro version, edit the material in your Deep Material editor and change the texture to any procedural material you like.
- DirtyMirror-Table.zip
- (996.83 KiB) Downloaded 1000 times
- dirtymirror.jpg (217.98 KiB) Viewed 15390 times
- DirtyMirror-Table_Scene 1.jpg (375.25 KiB) Viewed 15384 times
Users browsing this forum: Bing [Bot] and 15 guests
