hi res textures
hi res textures
Does anyone know other texture "manufacturer" than Arroway and Dosch?
I am looking for good quality textures as realistic as possible.
I especially need a walnut texture.
Thanks.
Jerome
Thanks.
Jerome
Re: hi res textures
CGTextures indeed has some really nice materials. Not everything is seamlessly tileable however and unless you are a pay member, you can only access the lower resolution ones however many times those are enough (especially with the SU 32 bit memory limitation).
Gai...
Re: hi res textures
I believe there is a walnut texture or 2 ready for Twilight here.
do none of thesework?
this looks promising:
http://naldzgraphics.net/freebies/200-u ... -textures/
Re: hi res textures
Thanks guys!
I knew CGTextures, but I find it rather time consuming to build myself bump/spec maps, and if it is not even tileable. I think I would prefer to buy a good quality texture. I guess I am not very good at it...
But then, one of my prefered texture is that Trespa white oak texture, which I built the B and S maps myself... I was very sorry to find their walnut texture not tileable...
I found another site that looks a lot like CGTextures: texturemate.com
About wood textures: Those "scanned A4 wood veneer" texture are not convincing me at all... I probably never spent enough energy trying to make them work. I'll try those kerkythea mats.
If I find anything interesting, I'll post it here.
Cheers.
Jerome
Cheers.
Jerome
Re: hi res textures
I made all the Trespa textures tilable myself.
I meant to share them here, and just haven't posted them yet. (like so many things I've made... that have been 98% finished)
Re: hi res textures
oh yeah??
I can be your beta tester if you want
Cheers.
Jerome
Cheers.
Jerome
Re: hi res textures
Are these any good? (I haven't looked)
Re: hi res textures
for smaller surfaces, maybe...
For wood texture, I think it needs long textures, unless very straight grain. Even if it tiles well, a more square texture (image ratio) will always look awkward.
The best wood textures I ever saw are Arroway's, but I dont really like how they did the bump and spec maps (though, it is good enough). The Problem is: they chose very crappy looking board AND they assembled everything with that silly "plank effect" that was trendy for 2 years... I am very sorry for them because it could have been such a great product, but obviously they did not know and listen the wrong advice...
Anyway, I think I will try to hack one of their textures, if it works great I'll post a small tutorial
Cheers.
Jerome
Cheers.
Jerome
Re: hi res textures
Have you seen these?
http://www.rendertextures.com/high-qual ... -textures/
They all come with bump and normal maps too
Also on the site:
Also on the site:
Seamless stone textures/19
Seamless bricks textures/13
Seamless grass textures/28
Seamless wood textures/38
Seamless pavers textures/25
Seamless planks textures/27
Seamless concrete textures/14
Seamless water textures/13
Seamless leather textures/21
-Marcus
Users browsing this forum: No registered users and 25 guests
