service tea
service tea
Just want to show how some of the program makes it possible to get good results. I use Neatimage and Picasa. All Renders took about 5 minutes with 09 easy . Original resolution is 1000x850. Resize images up to 80%. This produces a better quality. Is the original version and post-pro.
- before
- servic before.jpg (318.81 KiB) Viewed 12401 times
- after
- servic_after.jpg (119.74 KiB) Viewed 12505 times
Re: service tea
next
- before
- servi before.jpg (363.52 KiB) Viewed 12399 times
- after
- servi after.jpg (129.36 KiB) Viewed 12868 times
Re: service tea
next
- before
- service before postpro.jpg (273.66 KiB) Viewed 12399 times
- after
- service after post pro.jpg (264.59 KiB) Viewed 12874 times
- SketchUp: 8
Re: service tea
Congratulations for the images, can you explain the proces followed in the last two images? the change between before and after are very impresive.
Re: service tea
Impressive post pro, only point I can see (and this is getting picky) is that on the gold handle of the pot you seem to lose your AA, especially on the right hand vertical. The thing I like about leaving progressive renders longer is that they are so sharp, there's no AA blur. I like your first pair in particular
Re: service tea
process is the same. only had to reduce the image to 60%. because artifacts can be seen very well in the wider resolution.faluchdeviaro wrote:Congratulations for the images, can you explain the proces followed in the last two images? the change between before and after are very impresive.
- SketchUp: 8
Re: service tea
Thanks for the speed answer.
Re: service tea
alvydas,
Neatimage must be the best noise removal tool (even better now than when I last tried it). I have tried many many different noise removal tools and have never been impressed. But these results are impressive.
So you: rendered, reduced noise, edited in Picasa with some effects, and then reduced final image size? (this is similar to my workflow.)
Re: service tea
Fletch wrote: So you: rendered, reduced noise, edited in Picasa with some effects, and then reduced final image size? (this is similar to my workflow.)
guessed
- SketchUp: SU8 to SU2019 Pro
Re: service tea
indeed Neat Image is a life saver....particularly for internal renders
nice images alvydas....!
....by the way, what is the best method to reduce the size of an image...?
Users browsing this forum: No registered users and 32 guests
