Hi Guys,
this is a WIP of a function room that I am proposing
To share with you guys and get some comments
any C & C are welcome
Proposed Function Room
- function rm.jpg (656.82 KiB) Viewed 6028 times
Thanks n Rgds
Tom
Confucius
Tom
Confucius
- SketchUp: SU8 to SU2019 Pro
Re: Proposed Function Room
Nice scene...!!
Maybe tweak the the shiny metals a bit
And for me (this is just a personal thing and not a crit) the wall colour is good but perhaps adjust the hue a little (perhaps tending more toward a yellow/orange red (but still keep it bright and intense)....the reason i suggest this is because I recently used a dark Interface carpet (from the Dot Com series) and spent ages coming up with a red colour on a wall to give a similar effect (I spent nearly as much time on that one colour as I did selecting colours for the rest of the building....!)...I also found that the old trick of introducing adjoining white surfaces nearby gave the red a better effect (perhaps a white bulkhead over the bar might help and also it would define the bar area too....white can be your best friend in circumstances like this and it will give the carpet and the red wall a 'crisper' appearance, but I guess it depends on the effect you are after.....just a thought, not a crit
....and speaking of carpet.....it looks like an Interface floor you are using (or a similar random pattern modular carpet)...anyhow, my question is what carpet is it and where did you get hold of an image to download...??? Random patterns like that are difficult to produce and although your pattern is slightly repetitive it still looks pretty good. Nice effect...!!
Nice one, Tom!
Comments... hmm... That's a lot of red.
- SketchUp: 15
Maybe install some light fixtures to match the light cast on the red wall
Thanks for all the comments guys,
Gareth - I forgot what carpet mill n trade name it hv been with me awhile I hv a grey n brown
will attach for anyone who may any use for them, its 4 full size tile (quater turned)
rangerrick - I screwed up on this one I m rushing out for lunch appointment when I hit the render button
forgetting that I hv some item hidden, when I finally realise 1.5 hr later n slightly less than 2 hr B4
my next meeting n also it is a first proposal so I decided to just F**K it. I very most likely hv to amend
anyway...
Hv a good weekend
anyway...
Hv a good weekend
- wen c-tile.jpg (510.81 KiB) Viewed 5967 times
- wen c-tile-br.jpg (534.07 KiB) Viewed 5967 times
Thanks n Rgds
Tom
Confucius
Tom
Confucius
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 14 guests
