HI!!.. & problem with material..[RESOLVED]
Hi everyone!!!.. First of all, I would like to congratulate and thank everyone who's behind this AWESOME plugin (whoever they are). It seems so practical, easy and friendly!!!.. THANK YOU SO MUCH!!!. . (I think I'm officially moving from KT to TL..)
I'm beginning to practice with my old bathroom scene.. and it's really so simple!!. I just have this tiny little issue: I have a translucent glass screen, and wanted to put one of Fletch's translucent glasses from the library. I did it, and it changed it's appearance in Sketchup showing the new glass. But when I render it, it appears a plain colour. So I selected it with TR's material editor again and it shows as if it is the plain material from the wall (and I'm shure it's the screen as I selected it by the material name). I'm attaching the screen view.
What am I doing wrong here?..
Thanks again!!..
Thanks again!!..
- bath screen.JPG (202.81 KiB) Viewed 12458 times
Sandy
Re: HI!!.. & problem with material..
Try clicking on texture with dropper then go to templates -> Generic -> reset. Then try again, sometimes textures get a little muddled so by reseting you can normally fix it.
Hi Smiley. Thanks for the praise!
There are some "rules" regarding materials in Twilight (this should definitely go in the FAQ )
- Any face with a "Front" material applied will always use that material
- if not -- If that face is in a group or component, if that group or component has a material applied, it will use that material
- finally -- if the face has a back material applied, that material will be used
- SketchUp: 7.1
this should be called "Twilight material priority order" and be in the troubleshooting section of the manual, too.
Thanks guys for your quick answers!..
Well.. I read your answer Chris about 8 times, and still didn't get it all in!.. but you where definitely right in some point. It was grouped and I think it might have had a different material. Don't know exactly WHAT I did, but it seems it's turning out fine! (cooking now).
Another question: There is no way of changing the scale of a material used from the library?.. not even applying the desing, then going back to Sketchup and modifying the size there?.
Thank you so much again!!..
Sandy
Twilight doesn't do any modifications or manipulations for libraries. They are treated as "black boxes". So there is, currently, no way to change a library materials parameters. however, you can control the UV scale of the model itself by applying a texture to the model and sizing it. This will effect the UV scale of the library.
In general, we hope and believe that 99% of the materials a user needs can be created using the templates, which give you full control of color, texture, and size.
Loving TL more each day!..
Other questions regarding this same issue: I have a group of objects, for ex. walls, say with three diffente materials:
1. Is there a way of editing individually the materials inside the group, or I have to "explode" it?.
2. In case I accidentally gave the whole group a fourth material, how do I "reset" it?.
Thanks!!..
Thanks!!..
Sandy
- SketchUp: 7.1
1. Just double-click to enter the group and select individual faces.
2. There's a Ruby script that removes all group/component materials and leaves individual ones:
http://forums.sketchucation.com/viewtop ... 80&t=13711
nice ruby Miguel,
in order to remove the texture applied to a component or group in SketchUp:
- Select the group or component
- Right-click and choose "Entity Info"
- The Entity Info dialog should open (It's also found via "Window>Entity Info")
- There will be a box showing the material applied
- Click that material box and scroll up to the top left material, it will be the default material
- Click the default material as the material to apply to the component or group.
Users browsing this forum: Google [Bot] and 5 guests
