Corvette Stingray Vision 2008 Concept
- SketchUp: 2014 + 2015 Pro
Re: Corvette Stingray Vision 2008 Concept
Good skill! I suggest you render your model with some studio HDRI too.
See http://www.kerkythea.net/phpBB2/viewtop ... 7212#65638
http://twilightrender.com/phpBB3/viewto ... 587#p16587
Thanks for the hint and links, glad you like it, I'll try that tomorrow. In my first post is a try of a studio render but it's weak.unclebim wrote:Good skill! I suggest you render your model with some studio HDRI too.
P.S. Here it is. Preset 7.
- export 71.jpg (126.83 KiB) Viewed 10828 times
- export 71-2.jpg (118.69 KiB) Viewed 10828 times
Some minor tweaks to the body made today. I hope it isn't wrong posting SU modeling tweaks / screenshots, before rendering ...since it's called WIP, I thought it's fine.
- Hood - added some polygons - real life shape
- export 72-1.jpg (164.7 KiB) Viewed 10821 times
- Roof - same as the hood
- export 72-2.jpg (148.13 KiB) Viewed 10821 times
- Reshaped the rear-end, how the real lines flow.
- export 72-3.jpg (173.56 KiB) Viewed 10821 times
Finally, here is the metallic painted Stingray, thanks to Majid
- export 72-6.jpg (162.53 KiB) Viewed 10802 times
Mwahahhahahahah the orange name XD! Good to see it! Material deffinetely looks better
Congratulations, Kronox.LauraCristescu wrote:Mwahahhahahahah the orange name XD! Good to see it! Material deffinetely looks better
You need to work on creating a better studio lighting setup for the car.
Alex at Kerkythea forum was very good at this. Search his posts of car renderings at Kerkythea.net forum.
In Twilight, for the car glass:
use Library>Transluscent>Car Glass
Thanks Laura, thanks Fletch I made the windows black because the car doesn't have an interior yet ...I want to start modeling it but don't know where to start from and is one sophisticated interior...Fletch wrote:Congratulations, Kronox.LauraCristescu wrote:Mwahahhahahahah the orange name XD! Good to see it! Material deffinetely looks better
I'll give that a try
Edit : I followed Alex's tips on setting up a studio scene and here's what came out :
- export 72-9d.jpg (341.12 KiB) Viewed 10765 times
- export 72-9e.jpg (311.87 KiB) Viewed 10765 times
- export 72-9f.jpg (150.95 KiB) Viewed 10765 times
729d is looking pretty good. much better, actually. maybe a little over exposed, either adjust exposure in the camera settings of the render window, or adjust the lighting settings down so that they are not so bright before rendering. You can increase the exposure if they are too dim.
Reducing the intensity of lights maybe solved the problem.Fletch wrote:729d is looking pretty good. much better, actually. maybe a little over exposed, either adjust exposure in the camera settings of the render window, or adjust the lighting settings down so that they are not so bright before rendering. You can increase the exposure if they are too dim.
- export 72-9g.jpg (397.31 KiB) Viewed 10751 times
- export 72-9h.jpg (403.85 KiB) Viewed 10751 times
it did, try doing a bevel edge on the sharp edges of the car, sharp edges are not realistic look at any object, the edges are rounded by a couple of mm.
