Trying to get warm by fire. Doesn't have a clue.
Downloaded SU by Kha Anh Tu at SUTextures
Dumb Snowman
Dumb Snowman
- Christmas-house_.jpg (474.77 KiB) Viewed 8709 times
Re: Dumb Snowman
turned out very well
*edit - I especially like the lighting of the scene, really well done.
- SketchUp: Version 8
Re: Dumb Snowman
Jpalm,
Almost played with that model yesterday. Did you re-texture it? Yours looks better than the example shots for the model.
What did you uses for lights?
Re: Dumb Snowman
It's about to become water
Awesome render I like the fire.
Re: Dumb Snowman
I saw it and thought I better grab before you do.mgiambrone43 wrote:Jpalm,
what did you uses for lights?
Used night HDR ; Made the house trim brown
Didn't spend much time. Got fed up trying to get point light to work right so used emitters. Not a good idea but ..
I did redo some textures on house and mae some components so I could shut things off in front.
Thanks fletch.
Re: Dumb Snowman
Thanks kronoxkronox wrote:It's about to become water
Re: Dumb Snowman
Is there any way to change the segments on the wheel? When I build I use 48 segments. What is best for close up shots?
More segments, more poly's but...
I was always curious about this. When you look at the entity info it tells you the number of segments, but you cannot change them.
Re: Dumb Snowman
If you draw a circle or arc not connected to other geometry, you can type any number of segments into the Entity Info dialog.
