Design house...
Re: Design house...
Great lineJGA wrote:but there is nothing tinkering with an experts bits, if you pardon the expression!
Look forward to this, it's exactly what I need to get some more practise in.Chris wrote:Hey JGA, I believe Fletch is preparing just such models for upload to the Support->Resources section soon.
Re: Design house...
Are these Components you have in your SU components folder and add to the model independently of TR, but which recognizes there light properties?Frederik wrote:They're IES light components...
If yes, where can we get these components?
Re: Design house...
I've made several IES files myself and then I just place them in SU using Twilight...
Please check out the Create your own IES lights... thread...
fymoro has also posted some IES lights, which you can download from the 5 IES Spotlight effects (including SU model and IES files) thread...
Kim Frederik
Twilight Render Support
Kim Frederik
Re: Design house...
How you made this draw (decor)?
- DRAW.JPG (101.76 KiB) Viewed 14248 times
Re: Design house...
It was a decor I had in EPS-format...silu wrote:How you made this draw (decor)?
In Adobe Illustrator I exported it to a DWG-file, which I then imported to SU, applied to the wall and voila...
Kim Frederik
Kim Frederik
Re: Design house...
Hey... that cat is not Full HD. Good job, exept that soft shadows & floor thing... who am I !? Well...
Re: Design house...
In designing house,some various option has made for, because the quality used might need to have a support by them so that it will take a good advantage for the mixture of all design. I think that they need to have a method to make it comfortable.
Re: Design house...
How did you get the shadows so crisp? What sunlight setting did you use?
Re: Design house...
Hi Marypaul,
In the Light Editor Dialog for Twilight, there is a Sun and Sky Tab.
Find the slider that changes the soft shadow radius for the SUN.
Change it from default of 50, to be something like 10. This will give a very slightly blurred edge to the shadow, instead of the very soft shadow of default 50.
Frederick used "12" in this scene.
Here is a screenshot from here.
Users browsing this forum: Ahrefs [Bot] and 0 guests
