How would you do this light.
Locked
pbacot
OS: MacOSXMojave
SketchUp: 2019
Post by pbacot » Sun Aug 18, 2019 2:43 am
How would you set the light value and shade for this light? I have it set a little low as it was mostly decorative for the scene but I was surprised how low I had to set it to keep it from being overwhelmingly bright. How would you set real world parameters without it being too bright? Somehow it didn't seem equivalent to other lights I am using. I even tried an IES setting and that was surprisingly hot-bright. Also I added an emitter for the shade, while starting with a translucent shade default template.
sconce (rasmussen).skp
(42.01 KiB) Downloaded 1051 times
Here it is in a test scene:
Cabinet 19-8-16_sideboard.jpg (1.67 MiB) Viewed 20964 times
Just curious. I think it's OK as it is for my purposes. Thanks1
Re: How would you do this light.
Post by Fletch » Tue Aug 20, 2019 2:07 pm
pbacot wrote: Sun Aug 18, 2019 2:43 am How would you set the light value and shade for this light? I have it set a little low as it was mostly decorative for the scene but I was surprised how low I had to set it to keep it from being overwhelmingly bright. How would you set real world parameters without it being too bright? Somehow it didn't seem equivalent to other lights I am using. I even tried an IES setting and that was surprisingly hot-bright. Also I added an emitter for the shade, while starting with a translucent shade default template.sconce (rasmussen).skp
Subject: Translucent Material comparison
The emitting surface for the lampshade glass works great visually, but it renders very slowly unless you set type of Emitter to "Fake" so that it appears to emit light but does not do so. Then it will render quickly on Easy 1-7. It still emits light with Easy 09 or 10.
pbacot
OS: MacOSXMojave
SketchUp: 2019
Post by pbacot » Tue Aug 20, 2019 5:22 pm
Thanks. I only remembered that the emitter would not slow down easy 09 , but I guess there is no reason for the shade to emit in this case. I adjusted the shade down and the lights up to get the appearance of the light source behind the shade,
Now I guess I need to get some things to put on the shelves! (I don't know what they --owners and ID-- want them for. Maybe it's a modern tokonoma.)
ntxdave
OS: Win 10
SketchUp: 2020Pro
Post by ntxdave » Tue Aug 20, 2019 5:33 pm
Looking good.. :gj:
pbacot
OS: MacOSXMojave
SketchUp: 2019
Post by pbacot » Wed Aug 21, 2019 5:14 am
Thanks Dave!
Locked
Users browsing this forum: Bing [Bot] and 8 guests
