Hi!
I have problem with template materials. When i want to add metal setting to my material - steel/stainless steel, then rendered material is just black silhouette. Other metal settings work well. When i do explore rendering then everything is okay and material is showed correctly. What´´´´´ is the problem? Maybe someone can help me?
Thanks!
Metal material
Re: Metal material
exploration render is using a different rendering setting than your render dialog
which render setting are you using and which have you tried? clearly the material is not liked by the render settings.
Re: Metal material
for jewelry I suggest only Easy 10 render setting... it has best quality dispersion and materials in every lighting condition.
lighting is key with jewelry shots, check out this thread:
Subject: Diamonds, Wine Glass, and Spoon by Massimo
