Page 4 of 19
Re: How Fast Are You - Official Twilight Scene - Bauhaus Lamp
Posted: Fri Mar 26, 2010 9:42 pm
by Bob James
Downloaded your latest .skp version.
No render method chosen: 33 sec
Render method "Low" : 33 sec
Is this latest version different than the previous one? That's a pretty large change from 20 sec to 33 sec :shock:
Posted: Fri Mar 26, 2010 10:42 pm
ah, much better! Well, not sure what happened. Glad the camera is set correctly. Thanks for the follow-up.
With the lamp occupying more pixels, there's more to anti-alias, and that is the process that can take a lot of time.
Posted: Wed Apr 07, 2010 6:05 pm
by faluchdeviaro
My test on W7 64 bits.
image attached by admin
Posted: Thu Apr 15, 2010 6:27 am
by paappleb
Well it looks like I am the first to submit some results using an AMD powered PC. What can I say, I like being a little different. :lol:
AMD Phenom II X4 965 Processor 3.4 GHZ
8.00 GB RAM
Windows 7 64-Bit
Posted: Sat Apr 17, 2010 4:58 am
by Ecuadorian
My results.
Posted: Tue Apr 20, 2010 4:39 pm
by Solo
I'm getting the same issue as Scott, I tried both the skp and zip but view is further away, not sure how to correct it.
I got 17s but it's wrong view.
Posted: Tue Apr 20, 2010 7:39 pm
clicking "Scene1" doesn't choose the correct view?
What screen do you have? This is done with a widescreen.
Posted: Wed Apr 21, 2010 6:53 pm
by Solo
I'm using 2x 42" LCD's in dual mode.
Posted: Wed Apr 21, 2010 7:11 pm
I guess, just do your best to get it close to same view as you can... :? I'm not sure what could cause this. Maybe it's an issue with screen resolutions or something? (doesn't make any sense)
Posted: Fri Apr 23, 2010 10:49 am
by ScottPara
I did not have an issue with the file. It worked correctly. I am running dual 30" screens and that did not effect correct results.
scott
