Hi
I tried to export a file to KT but when loaded in KT there is nothing in there. What do i do wrong?
Export Kerkythea
Export Kerkythea
Re: Export Kerkythea
With the limited info you've provided, it's really difficult to say...
It works fine for me...
Have you tried to make a very simple scene and export it to a XML file...?
If it works, then there must be an issue with the model/scene you can't export...
i exported the same file with Exporter from KT (SUExporter) and it works
then the same file exportet via TWL Exporter and the KT file is loaded with nothing.
But i will try moore and you do not have to worry at the moment...
If the SU2KT plug-in works, then TWR should also be able to handle it...Zacchia wrote:i exported the same file with Exporter from KT (SUExporter) and it works
The great thing with the XML export function in TWR is that all Materials, lights etc. applied for TWR will also work in KT...
Strange... Really strange...Zacchia wrote:then the same file exportet via TWL Exporter and the KT file is loaded with nothing.
Are you able to strip the model and send it to support at twilightrender dot com...??
I'm sure Fletch will be able to debug it...
is this another .obj imported into SU?
If so, change the Grouping Method to "Per Material" in the Advanced Tab of the Render dialog, then re-export.
page 15 of User Manual wrote:It is not likely that you will need to change this method. Try this method if
having trouble exporting a scene to XML or to help in more easily editing
materials in Kerkythea.
it is an imported 3ds. But let my first ask how is it possible to load a big obj file into SU. Is there a good freeware somewhere?
If you need a obj importer for SU, take a look on TIG's Import OBJ with Materials.
