Color of Lights / Light Render Speed Comparison
Representing the color of light correctly is very difficult, and yet very critical for realistic results.
If you are looking to solve this puzzle sooner rather than later... here are some links to review...
Color Temperature Article in Wikipedia
A Kelvin Color Chart
RGB Values to 'start with' when you know your light source in Kelvin
The Light Render Speed Comparison below uses WHITE LIGHT. For more realistic render please put correct color temperature light!
This is NOT INTENDED to be the definitive answer how a light will appear, or how long it will take to render, it is only meant as a ROUGH REFERENCE GUIDE.
Individual results will vary.
- LightRenderSpeedComparison.jpg (240.88 KiB) Viewed 30938 times
Re: Color of Lights
Hi Fletch
It is interesting that you post a tread about lightcolor. I was surching long time and i have a question to you: Like in your picture i found yust something about Color Temparatur. It is fine but how do i set those Color Temperatures use in a render software? I need the color in RGB for a lightsource and i do not know how i can set a Colortemparature in RGB (how to "translate") Hope you understand
Re: Color of Lights
Just seen now your link:
http://planetpixelemporium.com/tutorialpages/light.html
This allready was what i was surching for!
Re: Color of Lights
There is an Excel tool which changes a color temperature into RGB.
Although it is Japanese and becomes empty.
If a value is put into T, it will change into a RGB value.
http://dl.dropbox.com/u/577270/K2RGB.xls
Re: Color of Lights
Most interesting, Tosiharu. I had always assumed that 6500k = RGB 100,100,100. I guess this is only true if your display device (monitor, projector) is calibrated for watching movies.
Re: Color of Lights
Zacchia,
glad you read the posted links further.
to explain to others perhaps in a "layman's" terms:
If you know your light source, you start from there....
"I know I'm rendering a desk lamp... It's got a common household tungsten incandescent bulb that's 60w"
ok...
so according to the chart:
we can see that the color in Kelvin is somewhere between 2500k-2900k.
so from the link above: RGB Values to 'start with' when you know your light source in Kelvin we can find the RGB equivalent to be about [255, 214, 170]
or opening the color chart shown above and sampling the color for that bulb in a photo editor, you can see the RGB value for it. This is only an estimate, and may require further tweaking to please your eye, but it's a good start. Remember that every monitor, and every printer will display that same RGB color a bit differently, so really unless you are calibrated well between your monitor and printer, and you have a very high-end monitor, the color will not be displaying to you "perfectly" no matter what you do.
Thanks to Tosiharu who is providing another way of getting this information.
Now that you know the RGB approximation for your light's color, use that for the RGB value in your Twilight Light Component. (pg 24, Twilight User Manual v1.1)
type it on the line like this:
That said, after experimentation with some lighting components in Twilight on my monitor, a color of appears to give a pleasing warm incandescent-like result yet is unobtrusive. I am not, however, looking for it to accurately reflect the color of a particular degree Kelvin... I'm just looking for it to look good in a majority of situations.
ok...
Code: Select all
rgb(255, 214, 170)
Code: Select all
rgb(230, 225, 204)
Re: Color of Lights / Light Render Speed Comparison
conversion kelvin in RGB and more.
http://www.joviancolorpicker.com/Downloads.aspx
u can make only 10 picks color but after u can use this exe
http://pourpre.com/colorbox/index.php
See also Itchy Animation's wonderfully done discussion/tutorial about lighting 3D models.
