Logo on glass
Locked
Logo on glass
Post by Fletch » Tue Jun 02, 2020 1:16 pm
Here's a scene demonstrating a logo on frosted glass.
Logo-Frosted-Glass.skp
(573.4 KiB) Downloaded 813 times
The logo is a .png file with clean transparency at the lettering and white at 90% transparent - created in Photoshop and attached below.
OPTION 1 requires a little modeling, but is simple enough:
Actually, the window is double-glazed (*edit - A single face of Thin Glass on either side of the "window" with glass face normals facing away from center of window where logo is located), with the logo inserted into SketchUp as an "Image" and placed "floating" between the two pieces of glass. The glass is "Architectural>Common" (aka "thin glass") basic Twilight material template.
The png logo image has no template applied. Changing transparency of the png is done in photoshop or other image editor.
Logo-Frosted-Glass_Scene 2.jpg (160.62 KiB) Viewed 12183 times
OPTION 2 requires no modeling, also simple:
Same logo - 90% opacity white with completely clear lettering in the .png file
Template>Frosted Glass>Heavy
tuna57
OS: MacOSX 10_11
SketchUp: SU 2015Pro SU2018Pro
Re: Logo on glass
Post by tuna57 » Tue Jun 02, 2020 4:03 pm
Cool solution Fletch. Figured you would know an easier way to skin this cat ! :rspkt:
pbacot
OS: MacOSXMojave
SketchUp: 2019
Re: Logo on glass
Post by pbacot » Thu Jun 04, 2020 6:43 pm
Looks great! Why "between" the glass--to keep it light? Double pane, is that 2 surfaces or 4? Actually I can never know until I try it in a render. Sometimes two sides to glass gives doubled reflections that look blurred or not enough clarity. Other times it seems to help. But I never do four surfaces myself.
Re: Logo on glass
Post by Fletch » Fri Jun 05, 2020 9:31 am
pbabcot, please feel free to download the scene and take a look. ;)
two faces, not four
This gives reflections no matter from which side of the window the logo is viewed.
This method of adjusting the opacity of the logo in photoshop and adjusting the reflection with the thin glass material in Twilight is quick and simple.
This could be accomplished with a deep material, but I wanted to give something quick and easy anyone can do.
Re: Logo on glass
Post by Fletch » Wed Jun 10, 2020 9:15 am
Updated post above to show another option for this Frosted Glass logo idea, the Frosted glass template looks pretty nice and is super fast to apply. :hat:
Locked
