Hey!
I am about to render a video walkthrough and i would love to have a screen with moving images (video) is that possible?
Thanks for help!!
Moving image in walkthroug?
Re: Moving image in walkthroug?
In Twilight Render Pro you can load a .gif into a material texture using the Twilight Material editor. Replace the texture with an image you import, and choose your .gif.
Set your walk through fps to match the fps of the .gif you have loaded into the texture for your TV.
Render with animation render dialog.
Or, for higher quality TV screen you can try using numerically sequential images as a texture source when rendering animations. Note that this is a Pro-only feature and requires a V2 license.
Just like when rendering an animated GIF, each rendered frame will use the next numbered image in the sequence (tex_001.jpg, tex_002.jpg, etc).
Users browsing this forum: Bing [Bot] and 9 guests
