Hi!
I have sketch up 2022 running on a Mac iOS, the twighlight hobby version is showing enabled in extensions manager but is not showing up as an option in my dropdown menu. I have tried uninstalling and reinstall rebooting everything with no luck. I also have v-ray installed as a back up, would this be the issue?
Twilight V2 hobby issue with MAC iOS- help
Re: Twilight V2 hobby issue with MAC iOS- help
Can you provide the specific version of Mac OS please?
Chris wrote: ↑Thu Mar 24, 2022 3:24 pm Please note, at this time Twilight Render does not run natively on the macOS M1 processor. If you have a macOS computer running the M1 processor, you will need to run SketchUp using the Rosetta 2 application. You can find out more about using Rosetta via this article from "MacWorld":
https://www.macworld.com/article/338843 ... stead.html
I have the same problem.
I have deinstalled and reinstalled everything and still no toolbar.
My macbook pro is new and the chip is M3.
Any help appreciated.
Did you follow the instructions in the post above about using Rosetta?
