New User - Dark Interiors
DapperDan
Post by DapperDan » Sat Jan 14, 2023 10:59 pm
I have (attempted) to attach a render and a cooresponding screen shot of a Sketchup model.
[Actually, I don't see a way to post an image. Am I supposed to upload my image somewhere else, and post a link?]
[EDIT:
I posted files below.]
The window faces South, and there are no lights other then the Sun.
In reality, the room would be flooded with light, but all my interiors are dark except for where the sun falls directly on them.
Am I supposed to modify every Sketchup material to make this program work?
Is this just how it is using Twilight, or is there something I have done wrong? All of the materials are stock Sketchup materials. I have not applied Twiilight edits to them.
Thanks for taking a look.
DD
Re: New User - Dark Interiors
Post by Fletch » Sun Jan 15, 2023 5:01 pm
:welcome: Dapper Dan!
These are very common first-timer questions. No worries, we will help you out. :hat:
No you don't have to modify every material. If you have Twilight Render Pro all of the default SketchUp materials will render with their Twilight Render equivalent materials (glass, water, wood, stone, etc.). However, if you are using the free hobby version, then you need to apply the Architectural Glass Common template to your window glass.
If your interiors are dark, you need to increase exposure of your image, just as your camera automatically increases exposure when you are inside with sun coming from outside. I also usually put emitter planes on all my windows, and I render with Easy 09 and Fastforward denoise addon for Twilight. I get great images in minutes with this approach.
Please watch our 6 Essentials video tutorial series linked in my signature below - it should cover all the basics for you.
In addition, see the video about sun through a window with sky portal material.
https://www.youtube.com/watch?v=sOeefZmVIB4
See also these posts about sun through a window and exposure:
Subject: Low illumination issues (includes downloads)
Subject: Light Through a Window
tuna57
OS: MacOSX 10_11
SketchUp: SU 2015Pro SU2018Pro
Post by tuna57 » Sun Jan 15, 2023 10:48 pm
DapperDan wrote: Sat Jan 14, 2023 10:59 pm I have (attempted) to attach a render and a cooresponding screen shot of a Sketchup model.
There is a small tab below the message window labeled “attachments” , click on that and you’ll get an “add file” button to take you where the image is for selecting or you can drag and drop your image into the message window.
DapperDan
Post by DapperDan » Mon Jan 23, 2023 5:51 pm
Here is a screenshot of the SketchUp view showing the Twilight Render settings I used.
I suppose I have the hobby version. I attempted to download pro version, but I'm not buying it until I can see if it works.
Here is the resulting render. The glass is grey tinted from the Sketchbook defaults.
It seems there should be reflected light in this room. The window faces South and is high in the sky.
Here I have removed the glass altogether. There is nothing in the window.
Again, shadows are too dark. There is very little reflected light working here.
Van no glass.jpg (304.91 KiB) Viewed 11178 times
DapperDan
Post by DapperDan » Tue Jan 24, 2023 2:31 am
Fletch wrote: Sun Jan 15, 2023 5:01 pm :welcome: Dapper Dan!
Thanks for the suggestions but that does not work.
I've watched some of the tutorials and read the light through the windows threads. See my results above.
DapperDan
Post by DapperDan » Tue Jan 24, 2023 7:54 pm
tuna57 wrote: Sun Jan 15, 2023 10:48 pm
Thanks for the pointer.
Any idea on what's going on with my renders? I added some images above.
tuna57
OS: MacOSX 10_11
Post by tuna57 » Thu Jan 26, 2023 4:59 pm
If you’re able to share the model it would eliminate a lot of guesswork at how you have things setup.
Post by Fletch » Fri Jan 27, 2023 9:35 am
:>: :>: :>: Download Twilight support edited scene here. Did you download this free example scene to try for yourself?
Without the scene to diagnose, it's all just guesses from our end.
Please post link to scene for further diagnostics. Please also share the specs for your rendering rig.
Hi Dan, which render setting are you using? What post-processing and exposure settings are you using?
DapperDan wrote: Tue Jan 24, 2023 2:31 am Thanks for the suggestions but that does not work.
Can you be more specific as to what you tried so I know how to help further? Your image posted above was not rendered with Easy 09 or even Easy04, and have the post process settings been applied as I posted in my screenshot above?
Here are some interiors I've done over the past year and you can make them with Hobby version if you follow my advice.
