Hi,
I noticed a render problem with my modell that I dont understand.
This is a printscreen from Sketchup:
In Wireframe mode:
And this is the output after rendering:
Does anybody have a clue what can be problem?
I am using Sketchup Make 2017 and everything els seems to render just fine.
Thanks.
Incomprehensible errors when rendering
- PAXuKTN.png (1.84 MiB) Viewed 1529 times
- dVhIEGY.jpeg (680.74 KiB) Viewed 1529 times
- M83XS9zb.jpg (1.4 KiB) Viewed 1529 times
Re: Incomprehensible errors when rendering
that is strange, but here's my guess -
In order to create a rendering of your model, Twilight uses a render engine under the hood called "Kerkythea". (KT for short) KT requires a mesh of triangles. So it triangulates irregular polygons.
Your model is showing a curve (many short segments that represent a curve) on one side of the street, and a single line on the other side. When this many-sided irregular polygon is converted to a triangular mesh for the engine, the mesh solution is not great. You can help by adding some key lines to break up that big multi-sided polygon of a road. See attached example.
On top of this, you should always assign thickness (30cm or a foot thick is a good start) to floors, walls, surfaces like this. Especially assign thickness to the ground.
- orig lines.jpg (101.47 KiB) Viewed 1527 times
- bad lines.jpg (145.69 KiB) Viewed 1527 times
- helper lines.jpg (126.39 KiB) Viewed 1527 times
