Hi,
I am having a real problem when I try to render a molding with a 45 degree angle (as shown in the picture).
I tried rendering it without a texture but that had the same result. I also tried fiddling with the solid and the twilight settings but I can't seem to figure it out. does anybody have an idea how to fix this?
ragged surface
ragged surface
- ragged surface
- ragged surface.jpg (450.68 KiB) Viewed 8381 times
Re: ragged surface
Can you share the .skp file?
Re: ragged surface
somehow when I put the solids in a clean sketchup file for transfer the problem just went away.
So thank you!
So thank you!
Re: ragged surface
I'm glad that worked for you, but it's important when you run into problems like this to be sure your geometry is "clean" or "good" geometry - which basically means that your geometry is not a mess of tiny triangles. Good quad modeling is best.
