Hi,
I'm adding two lights to the scene, at first , each one is a separate entity, but somehow, after a few tweaks all the lights start to inherit the same parameters, even the name of the light appears the same.
Thanks.
All light change at the same time
Re: All light change at the same time
Lights are separate objects and so that should definitely not be happening. However if you have a Component Definition with a light in it, all Component Instances of that definition will use that same light. It works the same as any other SketchUp component.
But otherwise, lights wouldn't suddenly merge. If you can provide steps to recreate the issue we can look into it.
Users browsing this forum: No registered users and 40 guests
