Magnifying Glass Scene
Post by Fletch » Sat Jul 10, 2010 12:39 am
Here's a scene for you to download and try... a magnifying glass.
The model is a rough estimation of a magnifying glass, not an actual true mathematical model.
It uses 96 segments in the arc, so that it is smooth glass.
It uses the flint glass template in "Templates>Realistic Glass>Flint"
Render "Scene 5"
The magnifying glass was positioned and focused only by positioning it first parallel to the ground plane and hovering it very closely above the subject, then rendering with the "Easy 01 Prelim" setting,
Then it was moved up and over and slightly away from the subject toward the camera. Then a prelim rendered once again.
Then it was moved only a little bit more to "fine tune" the focus with perhaps 3-4 prelim renderings to check the position.
It was rendered with Easy 09 Interior progressive render setting to 100 passes and then stopped. But it looked fine after only 10 passes.
It also looks good with Easy High+ but actually takes longer to render on that setting than with Easy 09, due to all the fuzzy tracing of specular reflections on most materials and the light emitting surfaces used for the studio lighting.
Please try it for yourself. :hat:
TwilightLogo-MagnifyingGlass.skp
(3.23 MiB) Downloaded 1919 times
TwilightLogo-MagnifyingGlass.zip
(1.19 MiB) Downloaded 1530 times
rclub24
Re: Magnifying Glass Scene
Post by rclub24 » Sat Jul 10, 2010 1:15 am
+1 8-)
I breakout in handcuffs!
d12dozr
OS: Windows 8
SketchUp: 8 Pro
Post by d12dozr » Mon Jul 12, 2010 4:13 am
Very neat effect, thanks for sharing Fletch :^:
I substituted TaffGoch's Geodesic weave sphere and rendered just for fun.
-Marcus
hvanessen
OS: windows 7
SketchUp: 7.1 pro
Post by hvanessen » Mon Aug 23, 2010 10:22 am
Wich material do you use in the sketchup file for the glass part. Do you use translucent or only normal grey color.
Post by Fletch » Mon Aug 23, 2010 3:39 pm
Fletch wrote:It uses the flint glass template in "Templates>Realistic Glass>Flint"
