And how does this work for TW 2.4.4
I can not assign an IES file to an emitter. In these examples you can, so how does this work for the current version?
pointlight / light emitter
Re: pointlight / light emitter
The question you asked previously about IES emitters was answered here: http://twilightrender.com/phpBB3/viewto ... =10#p36053
That post explains how to create an emitter material that uses IES lights.
Going over this subject some more in more detail (I hope). In the attached scene I just placed four POINT lights up in the upper end of the light well on each side. Using Easy 09 is there a reason instead to use SPOT lights, or an EMITTER texture? Obviously the source is not visible so I don't need the emitter for that. In the tutorials spot lights (or emitter for 09) are used for indirect lighting. That's better?
- 2019-2-7 WV Cave Hall_Scene 4x copy.jpg (387.48 KiB) Viewed 4203 times
