- OS: PC 64bit
- SketchUp: 2016-2023
Post
by Fletch » Mon Aug 31, 2009 7:19 pm
Our friend, Majid, a long-time Kerkythea user and new lover of Twilight suggests some simple things for all new users to Twilight, and even suggested we make them 'permanent' default settings.
We'll share them here as a courtesy for all to ponder:
Majid wrote: The first thing to do with Sun and Sky in Twilight to get a warmer rendering result:
- Change the default sunlight slider to between 3-7 so that prevents noisy and speckled shadows in clay renderings and low/prelim settings.
- Change max sun intensity , maybe to 3 or 4, to prevent over exposed renderings (you can always tone map the image later to brighten the brights and darken the darks)
- Set Sky Turbidity to 3, and the sun color to rgb(242, 225, 218) or similar warm color, this will avoid the bit of bluish tint you sometimes see with exterior renderings (otherwise one can do a white-point level balance in their photo editor, and use a bit of soft glow and warming filter to get a more pleasant warmth)
(parenthetical comments added for clarity)
Please feel free to try these suggestions and give us your feedback below. If enough people prefer these settings, we will consider making them the "default".
- SunlightSlider.jpg (52.61 KiB) Viewed 27923 times
notareal
Post
by notareal » Tue Sep 01, 2009 9:03 am
About the Sky turbidity, in my experience it breaks down if < 2 (clear) or > 10 (haze). I would not use physical sky, if solar angle from zenith is > 85 (near sunrise/sunset). The CIE Clear Sky is best approximated
with turbidity 2.3...2.5. (Note: this is general to all renderers that use Preetham Skylight Model)
JGA
- OS: win7 pro 64 bit
- SketchUp: 2015 pro
Post
by JGA » Wed Sep 02, 2009 2:30 pm
Any standardised settings which the experts use, has to be a good thing.
JGA
olishea
Post
by olishea » Wed Sep 23, 2009 9:47 am
Fletch wrote:Change the default sunlight slider to between 3-7 so that prevents noisy and speckled shadows in clay renderings and low/prelim settings.
which is the default sunlight slider? am i being stupid?
Oli
- OS: PC 64bit
Post
by Fletch » Wed Sep 23, 2009 10:05 am
sure... added to orig. post.
olishea
Post
by olishea » Wed Sep 23, 2009 10:24 am
thanks, i thought that just controlled blurriness. is there a way to increase/decrease sun strength? or is that the sky brightness?
Oli
Solo
Post
by Solo » Wed Sep 23, 2009 10:28 am
Put a higher value in the Intensity option, the default is 5.000
olishea
Post
by olishea » Wed Sep 23, 2009 11:33 am
thanks I get it now.
Oli
majid
- OS: Windows 8
- SketchUp: make 2017
Post
by majid » Sun Oct 04, 2009 4:29 am
as I have observed different sky at the same zenith-with eyes of a painter-, when the air layer is thicker (means that you are in a desert or sea shore) then sun goes more warmer than when you are in a climate with thiner sky (i.e. a mountain) where the sun goes more white. I don't know if the haziness can help? or just tweaking the sun color is enough?
- OS: PC 64bit
Post
by Fletch » Sun Oct 04, 2009 9:07 am
if you leave default sun and sky settings alone for Twilight, you will note that the sun color and shadows change with the time of day/location on earth. It is, in this way a "Physical Sky".
The subject here in this topic is that these shadows, for some people, may seem too soft, and these very soft shadows add to render times.
