Little Red Vanity
- SketchUp: 15
Little Red Vanity
Little Red Vanity: A couple of images, color, sepia version, SU mesh. Easy 10, 106 passes.
- red_vanity_800x602.jpg (217.9 KiB) Viewed 9968 times
- red_vanity_sepia_800x602.jpg (247.4 KiB) Viewed 8650 times
- red_cabinet_mesh_800x602.jpg (199.92 KiB) Viewed 9225 times
Re: Little Red Vanity
No Comment
- SketchUp: SU8 to SU2019 Pro
+1...!!
+1000
Yet, the metal strip seems to be too perfect, too clean. Try to use a anisotropy map for scratches and a small clouds bump to avoid reflections that are too linear, it needs some distortion (like nothing is perfect)
ARTIST AND DESIGNER DEREI.UK
High class, work, Rick!
awesome!!! I like it. would you mind sharing the DOF setting?
- SketchUp: 15
Thanks all.
See the Twilight User Manual page 38. (The table of contents says page 39, but actually 38)
Good advice. I understand what you are saying. I can implement the bump but not sure how to add the scratch map in Twilight?dereeei wrote:Try to use a anisotropy map for scratches and a small clouds bump to avoid reflections that are too linear, it needs some distortion (like nothing is perfect)
I set the camera focal point on the nearest cabinet pull,(ctrl, left click) then updated the scene to save that change. I used an F-stop setting of 4 in this render.jchau2007 wrote: would you mind sharing the DOF setting?
