Hi,
Just trying to improve my TWR skills with a model and render of a local stately home. Going well until I did a test render and getting strange results at the top of a window where the texture, appears warped. Can anyone shed any light as to what I am doing wrong?
Thanks.
Lee
Problem with warped texture
- problem.jpg (178.31 KiB) Viewed 6273 times
Re: Problem with warped texture
Projected texture?
A couple things to try:
first, make sure it is not a reversed face
second, subdivide the face of the arch with a few lines.
third, right click the face, and choose "make unique"
Thanks Fletcch,
It wasn't a projected texture, just a normal stretched texture.
The faces were fine and the addition of lines didn't help but 'making unique' sorted the problem, many thanks for your input.
- Sorted!
- sorted.jpg (181.95 KiB) Viewed 6248 times
Hm. This should not actually happen since Twilight can perfectly render distorted textures (quite exceptionally, too, I should add). Making unique is an ultimate and desperate step that can be a cure of many things but of course, it introduces new materials and additional hassle to tweak them.
How did you stretch that texture at first?
Gai...
Users browsing this forum: Bing [Bot] and 5 guests
