In my beerkkk english with google translate :
Hello
I wonder know if it is possible to make a wall transparent to the eye (I see inside the room) but opaque to light except through the exterior openings (windows).
Example: I chose an outside perspective. I run the rendering and I have a view of my entire room (not hidden by a wall) and only illuminated by light passing through a window.
Thanks
En français :
bonjour
Je voudrais savoir s'il est possible de rendre un mur transparent à l'oeil (je vois l'intérieur de la pièce) mais opaque à la lumière extérieure sauf au travers des ouvertures (fenêtres).
Exemple : je choisi un point de vue extérieur. Je lance le rendu et j'ai la vue de ma pièce entière (non caché par un mur) et seulement éclairée par la lumière passant au travers d'une fenêtre.
Merci
Exterior view ... transparent wall ?
Intel Core i7 2630 QM - 2,00 GHz
4 Go de Ram
4 Go de Ram
Re: Exterior view ... transparent wall ?
Using realistic glass template, illuminating only with Twilight Lights or Sun, and rendering with Preset Easy9 will NOT render caustics (light passing trough glass), so it might help.
ARTIST AND DESIGNER DEREI.UK
This works BRILLIANTLY! Nice job, Dereeei. Very creative thinking.dereeei wrote:Using realistic glass template, illuminating only with Twilight Lights or Sun, and rendering with Preset Easy9 will NOT render caustics (light passing trough glass), so it might help.
- Give your wall a thickness of 6 inches/15cm
- apply a color to BOTH SIDES OF the thick wall
- be sure the normals of the wall faces point away from the centerline. (the outside of the wall should face to the exterior, the inside of the wall should face the interior)
- apply the Realistic Glass Template to interior and exterior faces.
- Set IOR for the glass material to 1.1, set Alpha to 1 Set COLOR to “white”.
- Apply Material Template Architectural Glass No Shadow to your Window Glass. Make sure the windows are built with only one face of glass.
- Render with Easy 09
- InvisibleWall-Tutorial.jpg (212.95 KiB) Viewed 7975 times
- InvisibleWall-ShadowCaster.zip
- download sketchup 8 scene in zip file.
- (610.3 KiB) Downloaded 971 times
- InvisibleWall-ShadowCaster.skp
- download SU7/8 compatible scene in .skp format
- (1.02 MiB) Downloaded 1019 times
Very good !
Thankyou, it's exactly that i want !
Regards
Super !
Merci, c'est exactement ce que je souhaitais !
Cordialement
Regards
Super !
Cordialement
4 Go de Ram
4 Go de Ram
