Page 1 of 2
Playing with SSS and a 3D warehouse model
Posted: Tue Sep 08, 2009 4:12 am
by Ecuadorian
I used this model:
http://sketchup.google.com/3dwarehouse/ ... revstart=0
- out-SU.jpg (126 KiB) Viewed 14296 times
In case anyone happens to be rendering ice hotels, I assigned a "Subsurface scattering > rubber ball" template, with these settings:
- sss-settings.jpg (52.55 KiB) Viewed 14291 times
Used Preset Easy 09 and stopped it after the third pass. Took nine minutes.
- out-3passes.jpg (181.82 KiB) Viewed 14297 times
Inside the fortress
Posted: Tue Sep 08, 2009 4:40 am
by Ecuadorian
Another one of the inside. Again I stopped after the third pass. This one took 20 minutes and a half in my old Core 2 Duo. For this one I upped the exposure to 1.3.
- in-SU.jpg (95.73 KiB) Viewed 14281 times
- in-3passes.jpg (103.16 KiB) Viewed 14286 times
As you can see the model was not quite right (no thickness in some elements, reversed faces) and it lacks some
stalactites and random detail for added drama, so I'll probably end up building my own version of the Fortress of Solitude instead of fixing this one... when I find the time.
Re: Playing with SSS and a 3D warehouse model
Posted: Tue Sep 08, 2009 5:30 am
by fymoro
I like the mood of these images, thanks for the small tutorial,
Fred
Posted: Tue Sep 08, 2009 1:29 pm
by Ecuadorian
Overnight 83-passes render. 6h15m.
- out-83-passes.jpg (143.5 KiB) Viewed 14215 times
Posted: Tue Sep 08, 2009 2:17 pm
Very cool. I like the "inside" view best.
Posted: Tue Sep 08, 2009 2:56 pm
by Solo
Does SSS only work with progressive preset?
Posted: Tue Sep 08, 2009 3:04 pm
It can work with the others but won't look as good, and can add a lot of extra render time. At the lower end (Low, Low+) you may not get any results or you may get "estimated" results.
Posted: Tue Sep 08, 2009 3:27 pm
by Solo
I actually tried with low+ and got nothing, just a flat texture, and then with 08 and got this....
20 passes, 10 minutes.
and this is with low+
Is there anyway of getting the SSS to work like this?
Posted: Tue Sep 08, 2009 3:58 pm
SSS must use the Easy+
or use progressive rendering.
with Easy09, it's important to light scene with emitting surfaces.
Posted: Tue Sep 08, 2009 5:22 pm
by Ecuadorian
Solo, perhaps it's just a matter of having the right light sources, as Fletch said, and playing around with the SSS settings.
Here's a quick attempt with some seahorses, rendered with Preset 09:
- seahorses.jpg (15.03 KiB) Viewed 14118 times
This time I started with the wax template and used these settings:
- seahorse-settings.jpg (30.96 KiB) Viewed 14114 times
For illumination, the sky is turned off, but the sun is on, with soft shadows turned off. I used no emitters, but I guess you can get some pretty cool results with them.
If you can replicate the look of the dragon please tell us how you did it
The seahorse if from the warehouse:
http://sketchup.google.com/3dwarehouse/ ... evstart=36
