Yesterday night, unfortunately, I moved the "Twilight render window" outside my active SU window.
Since that time, I'm unable to see the "Twilight render window" in SU window when I hit the render button. I think the render window open always outside my active SU window now.
I have tried to remove and re-instal the plugin but the problem is always there?
Someone have a solution for me?
I think it will be interresting if all twilight windows (render, light editor, material editor...) had a reduce button like others program.
Thanks
Note: Sorry for my basic english
Problem with render window [RESOLVED]
Re: Problem with render window
Assuming you are using Twilight 1.0.6, there is a button in Twilight->Options->Dialogs for resetting all saved dialog positions. If you hit it, it will restore the Render window to it's default position.
Re: Problem with render window [RESOLVED]
Thank you Chris
I suspected that the solution should be as simple as that!!
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
