Hi there,
I've attached a screen shot of some materials that I want to render, but for some reason they are rendering with this unexpected blue overlay? Can anyone explain this phenomenon?
Every new material that I import is effected by this blue overlay.
Hope you can help, THANKS
Material's Rendering Unexpected Colour
- TEST.jpg (64.83 KiB) Viewed 6841 times
Re: Material's Rendering Unexpected Colour
And I forgot to say, those two materials are supposed to be light grey, and the one at the bottom is bright green
Can you post the model? That will probably be more helpful.
If you are rendering these tests using the Twilight physical sky (default) then the blue of the sky is causing the problem. Choose"sky type" - "sky color"and set the color to be a light grey, thats a good soft box lighting effect for test rendering materials.
