YASRT
YASRT
Don't panic, it's a Twilight work too, despite the name (YASRT = Yet Another Sponza Render Try ).
PT-P, 1015 passes, 6h14 minutes (sincerely I forgot it rendering!), no intervention other than inserting a sky background.
- No comment
- Sponza_PT-P (1015p-6h14m).jpg (47.55 KiB) Viewed 33519 times
Re: YASRT
looks great!
I would lift the dark areas w/ tonemapping before stopping the rendering using the camera tab exposure.
I would insert a background image using Twilight's sky.
but post-pro is completely legal...
if we get some great renderings from you guys it would be really great.
Re: YASRT
It has a sky background, Fletch.Dan wrote:...no intervention other than inserting a sky background...
Actually what is missing are more clouds, but I was in a hurry to take my Dia (http://www.kerkythea.net/phpBB2/files/dia_1_106.jpg) to a walk and was looking for a nearly clear sky to fit with the strong mid-day light, with just some rare clouds to be seen between the buildings - no luck All the backgrounds I tried with had the clouds covered by the building, so I decided to stick with this one, having just a little pale cloud (as you can see, at a more close look ).
Agreed with a little tonemapping, but I was interested to see the result straight from TWL (see again my quote of myself )
Re: YASRT
I meant that you can insert the background using Twilight.. no need for post-pro.
and you can tonemap in twilight before stopping the render (using Settings>camera tab panel) , so, again, no need for post!
but yes, I'm happy you have found some joy in it's use.
I guess we should have an internal sponza render contest for some website content creation... I have a good optimized version of it in SU somewhere....
Re: YASRT
So... The Sponza SU model I've posted in the Sponza thread isn't good enough...????Fletch wrote:I guess we should have an internal sponza render contest for some website content creation... I have a good optimized version of it in SU somewhere....
Re: YASRT
It's exactly the way I inserted the sky, Fletch but I liked the global lighting, so I didn't use Settings/Camera/Exposure.Fletch wrote:I meant that you can insert the background using Twilight.. no need for post-pro.
and you can tonemap in twilight before stopping the render (using Settings>camera tab panel) , so, again, no need for post!....
Your Sponza model is ok to me.Frederik wrote:So... The Sponza SU model I've posted in the Sponza thread isn't good enough...????
Re: YASRT
sorry Kim, I didn't look... is it optimized using instances?
Re: YASRT
guess I was confused because you said the word 'intervention' which implied to me that you did it in post pro... sorry for confusion.Dan wrote:It's exactly the way I inserted the sky
[/quote]Dan the man wrote:no intervention other than...
Re: YASRT
No worries, Fletch... I think I will survive...Fletch wrote:sorry Kim, I didn't look...
Yeah - it should be...Fletch wrote:is it optimized using instances?
