Force background image to render unaffected by lighting
Locked
Ecuadorian
OS: Windows 7 Pro 64-bit
SketchUp: 7.1
Post by Ecuadorian » Sat Sep 19, 2009 9:35 pm
Para ver la versión en Español, presione aquí.
Some users don't want to add a background in post-processing but prefer to place it as a plane inside SketchUp. Also, you might want to add images to TVs and computer screens. In all these cases, you might want the inserted image to render exactly as it is, without being affected by the sun/sky/lights in your scene. Here's how.
The following setting works perfectly for Exposure = 1.0, Gamma = 1.0:
1 - Explode your image so it becomes a texture applied on a plane.
2 - In the Twilight material editor, choose Templates > Light Emitter, any of them
3 - Set the Power (W/m2) to 150.
4 - Next to the light bulb, Change Emitter > Normal to Emitter > Fake.
5 - Unmark the "Cast shadow" checkbox.
Your material settings should now look like this:
If you're using a different Exposure value, use this simple formula to calculate the power for your fake emitters:
Power for your fake emitter = 150/exposure²
Examples:
For an exposure value of 0.5, you must set your fake emitters to 150/(0.5)² = 600.
For an exposure value of 1.2, you must set your fake emitters to 150/(1.2)² = 104.167
For an exposure value of 2, you must set your fake emitters to 150/(2)² = 37.5
In all cases, you need to keep a gamma of 1.0 if you want your images to render unaltered.
NOTE: Fake emitters only exist in Presets Easy 01-08. With Easy 09-11 they become real emitters, thus contributing light to your scene.
Feel free to translate this information to other languages and post it to the respective international forum.
Gareth
OS: Windows 10
SketchUp: SU8 to SU2019 Pro
Re: Force an image to render unaffected by lighting
Post by Gareth » Sun Sep 20, 2009 1:34 am
thanks for the handy tip Miguel :!:
Pg09
Post by Pg09 » Sun Sep 20, 2009 4:49 am
Great stuff like that should be added to the next version of the Manual...
Cheers,
Adam
Ecuadorian
SketchUp: 7.1
Post by Ecuadorian » Fri Sep 25, 2009 4:08 pm
As a note, the "no shadows" and "fake" settings do not work when using the Metropolis Light Transport render method (Easy 09 Interior and Easy 10 Interior+), but work well in all other "Easy" modes, including Easy 08 Exterior Daytime. This is because when using MLT all emitters, no matter their setting, become "true" ones, and cast shadows.
Locked
