Whaat's UV Tools and Twilight
It's not crashing SU or Twilight so I decided to keep Chris' topic clean but has anyone tried to use Whaat's UV Tools together with Twilight? To me it scrambles all the texture maps (both spherical and cylindrical).
Gai...
Re: Whaat's UV Tools and Twilight
Yes, I used it to apply spherical maps in a test scene:
You'll need to triangulate the mesh, Csaba...
Have you seen the explanation I've made available in the Earth & Moon thread...??
Thanks, Kim, I1ll try that. I must have seen it but it may have slipped my memory (and at least the Earth model is older than Twilight)
BTW it was made with circles of 96 segments. I can imagine triangulating that mesh!
Gai...
And YESSS!
It now works without triangulating!
Simply applied Porcellain template and rendered with 07 High + (no environment an such - this is just an UV mapping test)
Model in the Warehouse (an old one I posted once for a Help Forum discussion - if only the texture image were a bit higher resolution)
Gai...
btw if you don't have the subdivide and smooth ruby... could you also just export the model as 3ds and check "triangulate" faces?
I could have a try though.
oke edit: I exported to collada. Collada didn't triangulate... so I exported again as OBJ (check "triangulate faces") and import again and it worked
The idea is that now, you don't need to triangulate your model for it to render correctly. It will just render fine, without any modifications.
that's what Frederik says in this post
edit: you're right! ecuadorian
Collada export does triangulate. However when importing, make sure to uncheck "Merge coplanar faces" in the import options dialog if you want a triangulated mesh.
For this particular job there's fortunately no need to do this any more - thanks agin to development.
Gai...
Users browsing this forum: Google [Bot] and 0 guests
