SketchUp will not open after installing Twilight
Posted: Wed Mar 04, 2015 5:41 am
Hi all!
I am new to this forum, and potentially to Twilight.
In attempting to upgrade my rendering capabilities, I first installed Kerkythea Echo 2008 and it's Sketchup plugin. That plugin worked fine ... I did not like Kerkythea. I then found this Twilight plugin for Sketchup. Based on the screenshots on the web site, I was very excited about getting this installed and trying it out, so downloaded the "hobby" version (for now), and the .pdf tutorials.
After installing Twilight, Sketchup would crash when attempting to open. GRRR! Here is a screenshot of the BugSplat report details...
I checked a couple things that I found in searching this forum ... nothing helped.
I can move the twilight2.rb file out of the plugin folder, then Sketchup would start ... put it back in, it would not. Here is a screenshot of what Twilight installed...
I moved everything in the plugin folder out, and attempted to reinstall Twilight. This time, it put twilight2.rb in SU-8 plugins, and everything else in SU-7 plugins.
I then uninstalled Twilight from the control panel, restarted the computer, and again attempted to reinstall. This time, ONLY the twilight2.rb file installed ... nothing else. Same results ... SU will crash with the file in the plugins folder, will open if I get rid if it.
My computer / Sketchup...
- Win XP Pro - SP2 ... laptop
- Sketchup 8 - free version
- Microsoft Visual C++ (from control panel)...
As already mentioned, I am very excited about using Twight. What do I need to do to get this to work?
Steve
Steve
