alvydas wrote:Basically transparency of curtain can be controlled by adjusting the refractive weight. Here weight controlled curtains thickness. More weight - less thickness.If you want to have a special transparency map, it must be improved the refractive texture. Texture, wich have white or light gray color pattern, gives more transparency
Curtain Transparency - Deep Material Editor
Subject: translucent curtain material
