towel texture
towel texture
Does anyone have made any towel texture for use and want to share?
Re: towel texture
are you looking for some high resolution texture or is it only seen from a distance?
Re: towel texture
I was thinking somerhing for twilight material library. If not, a high quality defuse and bump.
Re: towel texture
Do you have an image example of a towel that you are looking for?
Re: towel texture
Like this but with realistic bump like grass i think.
- images.jpg (17.99 KiB) Viewed 10960 times
Re: towel texture
It is difficult to get good results with a bump map. If the towel is visible from a few meters, bump map is not needed. I think the texture is enough. Bump map is not necessary.
Here I used the normal map texture
- setup.PNG (274.78 KiB) Viewed 10956 times
- towel.jpg (696.61 KiB) Viewed 10956 times
- towel 1.jpg (365.94 KiB) Viewed 10956 times
Re: towel texture
textures
- colorful-beach-towel.jpg (680.28 KiB) Viewed 10953 times
- striped towel.jpg (547.56 KiB) Viewed 10953 times
- towel striped.jpg (599.6 KiB) Viewed 10953 times
Re: towel texture
and striped towel
Re: towel texture
how do you create normal maps? is there a program like crazy bump (wich i dont like at all) but more accurate?
