Hello, I downloaded a model of sink for a render to a client; I noticed that doing render "flat" is all white and not black and white - however most importantly setting the plastic material like satin (it happens with all the material) the render is incorrect as photos
In addition to a ceramic sink that does not reflect what would be the correct material to be set? thank you
SketchUp files: https://drive.google.com/file/d/0B3Fefo ... sp=sharing
error render
error render
- white render
- lavabo render 1.jpg (27.59 KiB) Viewed 9204 times
- render incorrectly
- lavabo render 2.jpg (32.63 KiB) Viewed 9204 times
Re: error render
I'm not sure I understand what you are asking here.
Your sink is floating in the sky - it will not look correct in any way until it's placed inside of a space.
Re: error render
Hello i downloaded a 3d file of "Agape Design" basin.
The original 3d file is black and white (varnished alluminium basin).
When i apply a material (plastic, alluminium o others) the image doesn't correspond to the real image of the basin. I would liked it to be all white (white varnished).
Please have a look at my image.
thanks!
thanks!
- Materiali.jpg (194.66 KiB) Viewed 9197 times
Re: error render
All the faces in that model are reversed, and both front side and backside have separate materials. So, Twilight Render chooses the front side material, but you are viewing it from the backside. That's why you get white (the front side material) and very reflective (viewing the backside). You will need to fix them in order to render properly.
It is always a good idea to check 3D warehouse models for front side / back side issues. Many (most?) aren't correct.
Re: error render
Thanks!
Users browsing this forum: No registered users and 62 guests
