For all Windows 10 users out there, please be aware that the Creator Update, which is a pretty major update to Windows 10, will probably invalidate your license for Twilight Render. We've included the reactivation instructions below.
You will need your Product ID which you received when you purchased your license. (This goes for AddOn licenses also!)
If you need to, download the latest version of Twilight Render V2 from our website at http://www.twilightrender.com/index.php ... ds/upgrade and install on the new computer / OS.
To activate Twilight Render.
1. Launch SketchUp and go to Plugins pull-down menu
2. Select Twilight V2 -> Options
3. When the Options window opens, click on 'License' on the left-hand side
4. If you are using Twilight Render 2.6 or ealier, under 'Computer ID', click on the Copy button. (This is not necessary if using Twilight Render 2.7 or later.)
5. Click on the activation link. It will open a webbrowser and point it at our website.
6. On the webpage, into the appropriate place, paste your unique Computer ID (if necessary) as well as your Product ID, and choose 'Activate'.
7. Your activation code will be emailed to the email address you used when making your purchase.
8. Copy this code from the email and paste it, into the appropriate place, in the 'Edit Options' dialog box and activate the product.
9. Restart SketchUp.
Windows Users, Creator Update
Users browsing this forum: Google [Bot] and 5 guests
