Chandelier Modern.
Chandelier Modern.
I am remaking models lost and coming up with some improved versions. This is a Chandelier that works in the higher render settings but is rather reasonable memory wise. I hope you find it useful.
- Chandelier Modern 3.skp
- (644.06 KiB) Downloaded 510 times
Re: Chandelier Modern.
preview
- mike1158-chandelier-modern.jpg (427.81 KiB) Viewed 6451 times
Thanks for that Fletch, I kept meaning to add a render but never got around to actually doing it.
I modified your light fixture to be less bright, set up with LED lighting. It's attached in the .zip file:
the light fixture given free on the forum by D12dozr
I also added a couple other fixtures, just as examples.
The key with all of them containing glass lamp shades is that they are modeled with a SINGLE FACE, and they use the Lamp Glass>Matte Twilight Material Template.
See the scene, attached for light powers, etc.
Important! The Rendered Image has the Tone Mapping settings in the Render Dialog set to Linear, Dark:2.5, Light:1.0
I have it here with I also added a couple other fixtures, just as examples.
- Light Fixtures.jpg (428.09 KiB) Viewed 6423 times
