Hi guys
Just playing around with some lightning and found this little simple software that can generate IES lightmaps!
Be carefull about changing the radius after loading the IES, it might cause a SPLASH!!
Happy rendering
IES generator
Re: IES generator
Hi Ark, not to sound ungrateful...
it appears you are re-distributing a software...
did you write the software or have rights to distribute it? If not, a link to the distributor would be courteous and probably actually required...
Re: IES generator
Hi Fletch
No I didn't write the software I'm afraid, but it's possible to download from a ton of communities. It's written by someone called Karba, but that's all the software tells. A little google search told that Karba is Russian, and that it's for download on his website if you can read russian!!
Anyway a link to a possible download is: http://www.tom-schuelke.com/ies-gen3.exe
I hope this is enough to shake of the Russian marfia
Re: IES generator
Thanks ARK, we appreciate the cooperation. I deleted the original, hosted file.
Just to add our own disclaimer:
Twilight Render does not endorse any third party software, nor do we certify that it is safe, free from viruses, malware or spam. Use at your own risk.
Re: IES generator
Some say this program is the best/well programmed free IES viewer/converter
http://www.photometricviewer.com/
- iesviewer299.png (104.31 KiB) Viewed 28421 times
Users browsing this forum: No registered users and 19 guests
