Trial #3....House and Pond
- SketchUp: SU8 to SU2019 Pro
an experiment using DOF for the moment
Easy 05 Medium +
Camera 1.4
.......will need to some adjustments to the model and scene, so it has a little way to go
C&C welcome to help make improvements
Easy 05 Medium +
Camera 1.4
- TWTrialA h100House and Pond.jpg (599.04 KiB) Viewed 12814 times
Re: Trial #3....House and Pond
That looks great, just enough foreground DOF.
Only thing is the grass that looks flat, I have some grass somewhere that you could scatter around (.png based) to give a more natural look, here is the grass thread: http://twilightrender.com/phpBB3/viewto ... f=26&t=463
Architectur_Twilight Library - try the "warped thin glass"
Fletch wrote:Architectur_Twilight Library - try the "warped thin glass"
Hi Fletch,
Okay thanks for pointing me in that direction.....i hadn't noticed it was there..... i will re-render but without DOF (to save time)
i was wondering if it is worth modelling the corrugated metal panels?
anybody ever does this?
the only place where texturing isn't perfect is the edge of the roof...
Cheers,
Adam
Adam
I do normally, unless the render is going to be at a far enough distance not to notice.i was wondering if it is worth modelling the corrugated metal panels?
Pg09 wrote:i was wondering if it is worth modelling the corrugated metal panels?
good point Adam.....when the view is a close as this one is, edge details like the edges of the corrugated roof do become a weakness.....i might try and reduce the thickness of the roof by 50% and see if that makes any difference
Adam,
I have found a file from a roofing supplier.....i'll give that a try too
.....the experimenting never stops....
here is a link to some roofing products for SketchUp :
http://www.steelselect.com/content/view ... hp?id=4532
....unfortunately, there isn't a corrugated iron file, but there might be something useful in there for somebody
here it is with the Warped Thin Glass.......looks a bit dodgy to me...!!Fletch wrote:Architectur_Twilight Library - try the "warped thin glass"
- TWTrialB h100House and Pond.jpg (607.54 KiB) Viewed 12740 times
Users browsing this forum: Ahrefs [Bot] and 21 guests
