Spring inspiration...
Re: Spring inspiration...
mind if I take a look at your grass component?
Not at all - I will send it to you shortly by e-mail...Fletch wrote:mind if I take a look at your grass component?
I just need to check a few things regarding a material lib...
I just realize that you will need a special material library installed in order to make my grass component work...
Not that it's a problem as such, but it would be great if we could have another material library system, in order to avoid clocking up the KT material libs...
hm:?:avoid clocking up the KT material libs
any luck? would like to take a look... I understand about the special mat. library being necessary... but you could make a lib. w/ that single mat. in it, and share the lib. file for me to put into Twilight's material folder right?Frederik wrote:I just realize that you will need a special material library installed in order to make my grass component work...
Here you go, Fletch...
Before opening the SU model, you need to install the Grass material library in KT...
(I know that you know that, but in case others want to try this scene...)
Butterfly are made by Patrick (aka MuseumMaker) and can be downloaded from >>here<<
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
