Hi,
I'm looking for a concrete mat like in this image.
Any ideas where I can find one?
I checked Kerky site but could not see one.
Searching for Concrete Material
- StLouis_04_R3_N04.jpg (90.77 KiB) Viewed 12845 times
Re: Searching for Concrete Material
Hi, Dylan. www.cgtextures.com has similar ones. If you want exactly the one in the photo, you can correct the perspective in Photoshop.
Also, Arroway has a couple of fine concrete textures (lower resolution versions available for non commercial use only but come with bump and specular maps):
http://www.arroway-textures.com/en/prod ... 1/contents
Gai...
Would you be able to use something like this...??
If yes, I will make it available here tomorrow (I can't make it today, since my FTP is on my home computer)Cheers
Arroway has sample textures, here is one similar to what you need: http://www.arroway-textures.com/en/prod ... 1/contents
I did a low rez test of the above linked free texture.
- concrete test Dylan.jpg (122.32 KiB) Viewed 12788 times
Thanks guys.
I decided last night, before reading some of these replies, it was probably better to model the joints and the holes and just find a concrete texture without them!
Maybe a mistake now, we shall see how it looks.
Those two Arroway concrete materials should be available from kerkythea.net (I did build them long ago from texture pack that Arroway did give for Kerkythea), hope they are not lost in void (kerkythea.org issue), Frederik should have those. I can look on this material again, later on this week (I have a feeling they they could benefit from a rebuild).
