Internal render with bright sunlight
One of my first twilight renders .It rendered for 10 hours and still looks noisy but it gives the atmosphere I was looking for.
- INT 1.jpg (596.99 KiB) Viewed 9844 times
Re: Internal render with bright sunlight
I like it
I would recommend, however, to use smaller sizes for your first renders, so they clear up faster.
Looks very good and it has own style
...fall down seven times, stand up EIGHT...
by the caustics on the wall from the mirror, I presume this is done with Interior 10+
this setting is 'the best' but very slow to clear up. I only use it when I have 'the time' or a serious network to render with.
I love this image...I like it much more than the graphic pen style version
I take it you can't share the floor texture? its a beauty, maybe too much bump but I like it like that!!
Oli
Over SCF he said it was an Arroway texture. If from the purchased, commercial (high res) library, itz's a pity he shouldn't. If the low res template, you can also download those (quite good from a "certain distance")olishea wrote:...I take it you can't share the floor texture?
Gai...
Its actually a low res arroway texture named Arroway woodfloor 041_d(along with bump map and ref map)As far as I know its downloadable.size is 1.1mb.
- SketchUp: SketchUp 8 free
Cool render! I like the furniture and sculptures.
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 14 guests
